Hi Trevor Hope the future will be as happy as the past must have been, Happy caravanning.Yes I will remember the good times with 55 years together and 40+ years caravaning there are lots of memories.
Trevor
Let us hope to meet up somewhere, life goes on, old friends and new ones to meet.
Hutch and Elaine, and Harry the dog.
Yes it got cold outside, Harry isn't as cuddley as Rex was. To keep me warm.You back from the pub already!!!
Spent enough to pay for a bar persons wages for a week. Venison Burger, and several beers. 🙄Yes it got cold outside, Harry isn't as cuddley as Rex was. To keep me warm.
Hutch a quick round of drinks already backLet us hope to meet up somewhere, life goes on, old friends and new ones to meet.
Everything was checked at it service I hope you have a great time at Filey 🙂We packed and ready to go in the morning to Filey dont think we have forgotten anything. Just as a quick reminder check your tyres and pressure on both caravan and tow vehicle as we have been parked up for 5 months +. Happy get aways everyone!
A bit of advice. Forget using the 3kw for heating as that draws 12.5amp leaving you with very little for anything else. Hot water takes priority over heating so you end up with a cold caravan or tripping the mains.My mind was telling me the 1,2 or 3kw setting was the heating, and wanting to test water only, i didnt switch that on. Unable to find where madam had hidden the manual its taken me most of the afternoon to work out something so simple. What a dummy. And yes, it works😗
Well I can honestly now say I have lived up to the title of this thread, have I ever forgotten how to caravan.
Having spent the last couple of days doing minor repairs, I then got round to firing up the various systems, and having tersted the Alde heating successfully, I couldnt for the life of me get the hot water to work. Ok, fairdos, its our first Alde system, and we have only used it twice so far, and then the long layoff.
I have always thought that hot water always took precedence to heating so no need to turn down thermostat?The hot water will be on on any setting, electric or gas. To give precedence to the hot water simply turn down the room thermostat so that the heating won’t come on.
You will have a setting you can use I think it’s “warm water”. (A bit odd as it gives more hot water), all this does is cancel the heating pump for a given duration. Useful for getting multiple showers, though not necessary IMO.
So gone are the days, of having the gas light on in the van for the heat, and replacing the mantels with the silk things, lighting them and then putting the gas on , to "pop Them into shape.The hot water jacket surrounds the glycol jacket, if the CH pump is on it will draw the glycol, (therefore), the heat away from that available to heat the water.
It’s a trade off. But only ever a problem if you are waiting on hot water.
Very interesting Clive.I’ve had the battery on the CTEK since November so disconnected it last week prior to checking it. After a week it was still well over 13 v. Then a sudden thought hit me. Since it had been on since November what were the electrolyte levels like. So I took off the cell caps and all cells were AOK.
So next step will be to retrieve the van and check out it’s bits and pieces and have new tyres fitted. Choice on reasonable quality 175/14C somewhat limited to say the least.
Hutch. A resounding no. The Apuljack units are light years ahead in performance and design over the BCA units. Check the spec. The electrical engineers will explain better than me. In fact Parksy’s Nordelectronica unit was rebuild by Apuljack a few years ago Using solid state technology.Dusty dog I am sure your new Charger /power unit is the same as our old BCA unit a smart charger, ends up a s a trickle then boosts to 14.8 v. Back to rickle.
I suppose if in dought read the manual.
See you soon maybe Norfolk,
I was under the misapprehension my LB was sealed for life. Never thought about checking the electrolyte. But I am sure my servicing engineer does.👍
I also assumed the CTEK was like my new Apuljack charger. Ie it could never over charge nor overheat the battery.
See some earlier posts on chargers from me and the Prof.
