Manual or Automatic ?
Page 6 - Passionate about caravans & motorhome? Join our community to share that passion with a global audience!
4,464
A question for those with EVs please.
How slow can you reverse with an EV without any shuddering. The J word may not be PC😉
Like others have said I haven't encountered an slow speed issues with my PHEV which always moves off on electric only. However it only solo and I don't tow with the PHEV.
Aug 18, 2024
326
214
935
I doubt that you are sorry.
What’s so hilarious about it. Would welcome your reply when you have regained your composure. Would “ control of the clutch” be more acceptable to you?
Sorry, I genuinely thought you were joking
.You are joking aren’t you!
Nov 30, 2022
2,013
1,915
Torque converter diesel auto.
When on cruise control, if a gear change is needed it happens without dropping out of drive like a manual does the moment you touch the clutch.
Auto is far more relaxed to drive in traffic.
Just about every new lorry is an auto now, virtually impossible to buy a manual. When I worked for a coach company in around 2018 they made a management decision to only purchase coaches with auto transmission because the maintenance costs were proven, by the industry, to be less.
No way on the planet will I ever go back to a manual. (But I woukd only consider a torque converter auto as there are no clutches etc to wear out,unlike a DSG or similar. Personal opinion of course)
2,776
Actually Torque converter gearboxes DO have clutches.
Many years ago a friend had a Ford Corsair Auto that seemed to slip. We took it to a local specialist (an ex copper). Who diagnosed the ‘front clutch’. Repair was quick and cheap as it could be accessed through a side panel without having to remove the box.
Googling tells us they still have clutches. But they are now lock up clutches.
5,523
I see where you are coming from John.
All auto boxes , TC or DSG contain a form of clutch , a brake band.
The TC is not a clutch as normal but a fluid flywheel assembly using hydraulics as the clutch. Once the engine is warmed up the flywheel TC assembly will lock as in a manual.
I have no wish to be pedantic but the word clutch in any auto box can mean differing things.
Reactions: Mr Plodd and RogerL
5,523
Like others have said I haven't encountered a slow speed issues with my PHEV which always moves off on electric only. However it only solo and I don't tow with the PHEV.
Would you say slow speed as slow as “creep”?
2,776
I have now wish to be pedantic but the word clutch in any auto box can mean differing things.
My example referred to a 1960’s car. Regarding the ‘front clutch’. It felt just like a manual with a slipping clutch. I dare say that Torque converter boxes have improved since then.
However, according to this, they have multiple clutches.
The Absence of Traditional Clutches
Unlike manual transmissions, which rely on friction-based clutches to engage and disengage gears, automatic transmissions operate without traditional clutches. Instead, they utilize multiple internal clutches and bands that are actuated hydraulically to control gear engagement and disengagement. These clutches and bands work in conjunction with the torque converter to facilitate smooth gear changes and optimize power delivery to the wheels.
9,532
No I’m not. So what’s so funny?
The Swedish national police changed their fleets of manual Saabs to auto Saabs and operating costs reduced and availability increased. Despite the officers’ misgivings their acceleration times reduced and they eventually endorsed the move.
Reactions: Mr Plodd
Aug 18, 2024
326
214
935
Sorry, but it just is! Do you have electric windows, or do you still prefer the winding ones?
There is simply no comparison to driving, towing or off roading with the modern Auto compared to, a now, totally pointless manual
Especially with a parking brake lever! đŸ˜‚đŸ˜‚đŸ˜‚đŸ€ŁđŸ€Ł. Sorry, but it IS just so funny. I will gather myself together now. 👍
Aug 18, 2024
326
214
935
Saab have not made a car for ten years! đŸ˜‚đŸ˜‚đŸ€ŁđŸ€Ł Oh stop it
Please!
Ps: Love the dogs btw! 👍
May 30, 2024
126
155
635
See, I'm kind of with otherclive on this. I drive quite a few different cars, and for all their smoothness in most circumstances I find most BEV's and DCT autos to be really quite irritating when it comes to precision creeping movement - like when parallel parking for instance. Very difficult to control the last few mm - not helped by hysterical front and back sensors which can both be going off at the same time if it's a particularly tight manoeuvre. Electric parking brakes, autohold and so on, make the transition between moving and not moving totally binary. Analogue can be more enjoyable.
2,776
It depends.
I have had just 5 auto cars. Starting way back with a Morris Marina, so not very up to date.
The SsangYong 2015 was controllable at slow speeds, but had very harsh gear changes. Then the Volvo V70 was just about perfect. Followed by an MG ZS which was just as you are describing at low speeds, (it is the reason I got rid of it), but gear changes were fine. My present Mazda is like the Volvo, excellent.
Cars are not all the same.
I would prefer an old fashioned hand brake even though my current electronic one releases smoothly.
I once had a manual Citroen XM with a foot operated hand brake. It was released with a hand button. Once I got the hang of it, hill starts were easy enough.
326
214
935
I also have a Ford Ranger Pick Up manual, and I often park by feel!
But control the last few mm! That’s an interesting concept. I have never had an issue controlling an auto, either when parking, or using the reversing camera to hitch my caravan
..Never! Perhaps you’re a little heavy on the throttle, and I see absolutely nothing enjoyable about an “ analogue” parking brake, and I have both.đŸ€· But we are all different. 👍
9,532
Please!
I was just making the point that many consider automatics as potentially unreliable, but even back in the 1990s Saab demonstrated that wasn’t necessarily the case. But then the automatics were torque converter types not the later twin clutch or CVT. Having had a Saab 9000 CSE turbo which was an excellent tow car I’m aware of Saabs sad demise in 2011.
Oh and the dogs crossed the Rainbow Bridge last year.
9,532
It depends.
Careful now John calling it a “ foot operated hand brake” could make you a target for hilarity.
Reactions: Jcloughie
9,532
Have you used a twin clutch auto for close quarter combat such as hitching up, tight parallel parking etc. That's what my comment was about in post #123. I had my first auto in. 1986 a Volvo 245 GLE, and have had all three types of automatic boxes, so I’m experienced in driving cars with auto boxes and do prefer them for towing.
5,523
Imo the T.C Autos are best for manoeuvring providing the auto hold brake is switched off.
I’m still not clear just how slow the EV can manoeuvre? I suppose I should try my sons Volvo😉
9,532
Are you talking Twin clutch or Torque converter auto. In my experience the latter is superior especially when matched to a diesel. Be interested in the test if your sons Volvo. But don’t forget there are several different types of EV powertrain so it’s not a one size fits all.
Reactions: Mr Plodd
9,532
Seeing as I consider the dogs far more important than debating the superiority of the modern auto to a manual, I am sorry to hear that. I have an auto, a manual and an ESS. 👍
We at least we have something in common, as we have auto and manual too. . The current dog is now a 2 year old rehomed Sprocker, with boundless energy, pulls on lead and doubtful recall, and fears nothing. Even felt sorry for the Collie-Springer this week. :)
1,105
1,046
5,435
It's dependent on the car. My Polestar low speed control is incredibly good. The throttle response gives astonishing levels of precision. Our Fiat 500E - not so much. My youngest Corsa E is also very good.
4,464
How slow is creep? I don't see a difference, I have had no issues with any sort of slow speed control.
If it starts to creep too quickly, I believe VW fitted brakes. Maybe I'll have to look for them, Ah found them, always wondered what the second pedal was for.
  • Haha
