- Jun 16, 2020
- 5,884
- 2,789
- 17,935
Air con, whether as part of climate control or not, does not only cool the air. It dries it. Hence the condensation seen below the vehicle when you stop, this is why air con will operate whatever the temperature in order to demist. It is also why the air con is on when heating is required. Air, fresh or recycled, is filtered then chilled and dried prior to being passed through the heater. Some commercial systems also have a washer fitted before the air con. But never heard of that in a car. As said already, humidity sensors are fitted. It’s used to be sold as a safety feature, as it can help to keep the driver alert.
I just leave mine switched to auto with air con on. CC will operate with the air con switched off, but with reduced functionality.
I did have one car in which the air con evaporator would freeze solid. But this was due to high humidity not cold temperatures.
