Our 2018 Buccaneer Cruiser went for its 4th service yesterday with AWS technician who is fanatically thorough. Caravan has not even done 1000 miles since last service with dealer. Previously all servicing was done by the Buccaneer dealer.
Sad to report that 42% damp found around the ALDE hot water boiler area otherwise all clear. He could not establish where there was a leak as it seems to be concentrated under boiler which is under the front offside bunk. Dealer will probably need to resolve.
Our bulkhead regulator which has two outlets has a leak 30mbar in 10 seconds from the connection that is not being used despite the fact that it is switched to the bottle being used. Can either replace bulkhead regulator or fit a cap. Not sure where to get a cap for that regulator or even where to buy a replacement regulator? Anyone help? Thanks.
The AWS also mentioned that when he removed the wheels he found that the brake linings and pads were covered in grease. He removed all the grease. I am now wondering if they were deliberately covered in grease a few years ago when we complained about a loud squeaking noise coming from the caravan when towing it slowly i.e. on a site?
Also it was pointed out that the fridge was not room sealed and fumes could enter the living space. Apparently with the outer vents removed, if you looked over the top of the tall fridge you could see a gap?
I did noticed a lot of groaning towing the caravan back to the storage site and it was really loud. I put it down to not removing the towball overnight although it had a cap on it. I did not clean it before hooking up as thought no need as only over night. Not sure when we will be going away again during October although may be out and about in November.
