The OP is not abroad and is buying a UK caravan which has one sticker showing the MTPLM. If an upgrade is required, the original sticker is removed and a sticker with the new value for the MTPLM is put in its place. Simples!
I never said the NCC label was the official PLM I hoped I made it clear the NCC was a local suggested value.If the OP were abroad and bought his caravan there it wouldn't have an NCC label by the door (or anywhere else).
One can't have two legal MTPLMs on the same caravan. Either a permissible laden mass is a maximum or it isn't. How can two values which differ from one another both be a maximum? Only one can be legal.
I don't recall anyone stating it was a legal sticker. After all the sticker on the side of any caravan is not mandatory so need for it to conform to any legal requirements, but that is another debate that has been done to death on this and other forums and the OP probably has no interest in any legal arguments.The photo that the OP has posted of the sticker on his caravan doesn't conform to legal requirements so there must be another weight plate elsewhere which does.
Consequently any sticker on the side which doesn't conform to requirements can safely be ignored or removed. That's surely a non-issue which doesn't need to be discussed further.After all the sticker on the side of any caravan is not mandatory so need for it to conform to any legal requirements, but that is another debate that has been done to death on this and other forums and the OP probably has no interest in any legal arguments.
You are undoubtedly correct, BUT as has been discussed before, the UK caravan dealers, caravan buying public AND some police officers believe it is a necessary label and trying to argue your own version (again, which I believe to be correct) at either a point of sale, roadside check etc makes it simply not an arguement/discussion anyone wants to have.Consequently any sticker on the side which doesn't conform to requirements can safely be ignored or removed. That's surely a non-issue which doesn't need to be discussed further.
The UK's association with caravan weights and percentages has been around for so long that many regard it as a directive that simply must be followed.
When you get it weigh absolutely everything as you load it, even bits that seem irrelevant (toilet rolls etc), trust me, you'll be amazed at how quickly it adds up! I do this every time we change the caravan and end up throwing stuff out, there's only the three of us but we seem to end up with enough cutlery and plates to hold a Royal banquet!!!!!Nope, I’m just hoping the weight upgrade will be a good allowance, which allows us to use if we so wish.
Won’t be going near it, but just a nice to have![]()
Haven’t your dealer said what the upgrade will be?Nope, I’m just hoping the weight upgrade will be a good allowance, which allows us to use if we so wish.
I noticed that the other day when you first posted. I suppose it could well be that your particular model has optional extras fitted that has bumped the weights up? We're currently looking at an Adria and the spec sheet lists 2 x MIRO's and 2 x MTPLM's for the same model depending on options fitted or not. I wouldn't get too hung up about it as the differences isn't much.
The "M" in MTPLM is an abbreviation for Maximum - but the caravan industry can't cope with the perfectly obvious.I note that, in their tech spec, Adria refer to a, quote, MTPLM-min. What are they playing at? Either it's a maximum or a minimum. How can it be both at the same time? One can be a standard MTPLM and the other an optional MTPLM, but not a minimum and maximum MTPLM. If the terms 'minimum' and 'maximum' are used, then this suggests that there is also something in between.
That gives you more than enough to play with, probably more than you may need but it’s nice to have the margin. Make sure tyre pressures and LI reflect the change. I had a Bailey where the MTPLM was increased to within 20 kg of the maximum load the tyres were rated for. So I fitted new tyres with a higher LI.Just confirmed from dealership.
The weight plate can be upgraded to 2000kg
